The former owner Ed Collins has been very helpful and given me a lot of new information about the boat. From one of his e-mails:
The V drive acts as one bearing while the one in the hull acts as the other. The one in the hull is called a "cutlass bearing". That one has ALWAYS been hard to remove. I let the guys at the boat yard do it, and they always cursed at me for it.
I just remembered that the "packing gland" had some sort of rubber hose that connected it to the hull. I would replace the rubber AND the clamps as I never did in the 11 years that I owned the boat.
Good luck
Ed
He also told me the hull number was 26, and a lot of other details and history of the boat. I will inspect the cutlass bearing with an endoscopy instrument, and see what it looks like. I am not so keen on replacing it yet. With the new hydraulic drive the speed on the propeller shaft might be different. If the condition on the bearing is not too bad, I will try to use it this summer. It will only be a short season with not too much use. No long trips. It will be more like small test runs, so when I know the rpm on the engine and propeller shaft and got some feeling for what is best rpm, it might be time to replace the propeller, propeller shaft, cutlass bearing and packing gland. If I need to get down the rpm on the propeller, I might go for a three blade propeller. But this will be next winter. Now I need to decide what to replace for only 4 months use. I think I will find a slimmer offer anode so the shaft will be 2 cm closer to the hull. There should be room around the propeller for this, but I will check it. Also the rubber and the clamps will be replaced with new. The stuffing box will be inspected.
But if the old propeller is working fine, I think I will keep it. When it is closed it looks like it will give very little drag. I think a new three blade will give more resistance when sailing.
