If you will be bringing the coupling and the shaft to a machine shop to get the key way issue straightened out, and to get the coupler fit and faced to the shaft (which you should do), then just have them drill the dimple while they are at it. Done. Also, it wouldn't hurt to have them lap the taper for a good fit to the prop hub--though you can certainly do that yourself. But again, if they have all the parts, just have them take care of it all at once.RE problem #2
Yes. Drill a dimple on the shaft. Mine was surprisingly easy to drill. I did use a hardened drill bit and it easily cut into the shaft.
I agree with others who say the 3/8" is probably a typo. But rather than guess that it should be 1/8" (as it is for my stuffing box for a 3/4" shaft also), you really should contact Buck Algonquin and figure this out for sure. E-mail them at sales@buckalgonquin.com. It may be that it takes something else, since there is no necessary uniformity between shaft diameter and the stuffing box packing size; it depends on the box. Please share what they tell you, by the way, because I am planning to buy the identical stuffing box for my haul out in Ensenada next April and it would be good to have the correct packing in hand.
I will say that *if* that box takes 1/8" and you were trying to put 3/8" packing into it, you probably had to hammer it in! If so, that right there tells you it can't be correct. Packing should fit snugly but not tight, if that makes sense. It should not be sloppy loose, but neither should it be too hard to press in. There should be some friction getting it in but not too much. I know my description is vague but I'm not sure how to quantify it. But I will say that if you had a hard time getting it in, and my guess is that you did, then you can figure that the packing is the wrong size.
As for mixing packing sizes in the same box: don't do that.
As for 2 vs. 3 rings: With the right packing, you'll probably be able to fit 3. But I don't think the number of rings is an end in itself. The goal is to keep the water out, other than the small amount needed to lubricate the shaft. Whatever accomplishes that is what you want. Normally that is 3 on boxes like these.
Thanks for posting this! I appreciate it because, as I mentioned, I am going to be obtaining the identical packing box. So I will get 3/8" to have on hand for the swap and will only use 2 rings. There's nothing magic about 3 rings in these boxes, so what Mr. Cadmus says makes perfect sense to me.No I didn't have to hammer it in. It took some firm thumb pressure but it went in relatively easy. The 3/8 packing went in fairly easy and only needed to tap it with a hammer/tool to seat it.The area inside the nut is WAY bigger than my previous one (see above picture). Thanks for the email and I got a response. I guess they want you running 3/8 packing with only 2 rings.
Sounds like your on the right path. On most sizes we recommend 3 rows of
packing but unfortunately for this size 2 rings is about all that will fit.
2 rings will be fine just make sure you stagger your seems. Hope this helps
out. If any more info is needed please feel free to contact me.
Nick Cadmus
Engineering Manager
Hydrasearch Company, Inc
Were you able to get it adjusted correctly with the 2 rings?
Yeah, removing the bearing really was that easy. Of course, that method requires you to have the shaft already out. We removed the old shaft in a few minutes because we were replacing it and just cut it with a cutting wheel on a grinder. It was a bronze shaft that cut like butter!
Well, it wasn't all that hard to turn the wrench; you can kind of tell from the video how much we were leaning into it. I guess yours is just especially tight. I take it you did get the washers exactly the correct size?Well apparently it isn't just that easy... I can't get it to break free and I'm about to call in the pros. I tried your trick and nothing moved. On a side note, how hard did you have to wrench to get it to break free? I pried pretty hard but I don't want to break the strut. Should I go all in? Also, I tried cutting it out and it still won't budge. I sanded down to the metal on the strut to make us there weren't any set screws- nope. I cut out the rubber and I'm going to give it one more try with thicker all thread and a shorter pipe. Any other suggestions?
Juicd
