907Juice
Continuously learning
UPDATE! Need some help
So I cut out the bad chunk of wood under the mast and banged around with a hammer and drilled a couple pilot holes. The core seems hard and still in tact. FWEW! That should be an easy fix.
My problem is- I cut off the nuts to the prop shaft flange and everything seems to be ready to separate but they won't come apart. I tried tapping the flange with a hammer and tapping the seam with a screwdriver but it won't break free. People have recommended grinding the flange off and moving on but I'm confused on where/what to grind. Please be specific. I've attached a few pics. The part I ordered is only the prop side of the flange. The transmission side of the flange looks like it attaches inside the transmission so I'm afraid to cut it off. Should I get a bigger hammer/chisel and bang harder on the seam, or is there a better way to split it?
And help is appreciated!
How things look now.
Hard core under the crack.
