Bottom paint layer details
Mark,
Here are some detail pictures from my bottom sand and paint in August. My paint was not thinning down to the grey barrier coat underneath, except at the waterline, but it was last painted in Oct, 2009 and the paint had lost all effectiveness showing heavy fouling and even hard barnacles.
I was only planning to be out of the water for a week. I was planning on a light sanding and two coats of paint, plus zincs on the prop shaft and strut, plus replacement of a thru-hull and my speed transducer. After light sanding of the old bottom paint I could tell it was well attached to the grey barrier layer under it.
You can see how the red bottom paint mostly came off the rudder down to the grey barrier coat. The two white spots in the upper front indicate where I actually sanded through the grey barrier and down to the white gelcoat. This will have to be repaired in the future in order for the barrier to be effective. In the detail picture of the waterline, you can see the layers of paint that I have. I only had red bottom paint (two coats per the previous owners Oct 2009 yard bill) and no other colored layers. Under the red bottom paint was a grey barrier coat ("epoxy seal" per the Oct 2009 yard bill) that was harder than the red. I suspect I only have one coat of barrier because it seemed thin and I didn't find alternating grey/white layers. Barrier coats usually are applied with around 5 alternating white and grey coats to get ~ 10 mils total dry film thickness.
Under my grey barrier you can see white gelcoat and the two blue (thick and thin) factory gelcoat boot stripes - my bottom paint covers the boot stripe on the stbd aft side of the boat to account for the heavy fuel tank.
You may find that your hull has various layers of bottom paint, but it doesn't sound like it. You may also have no barrier coat, just white gelcoat, but check carefully because the barrier coats usually are applied with alternating white and grey coats. So the outer barrier could be white like the gelcoat, but any sane person would start and end 5 coats of barrier with the grey coat. If you wish to add a barrier coat, before you apply bottom paint, you will need to get all the existing bottom paint off, down to the gelcoat. If your existing bottom paint is really thin and sands off easily and you have the time and energy, you can sand it off yourself. Or you can have it removed via blasting. Once the bottom is down to gelcoat you need to make sure the moisture levels in the hull are low before you apply the barrier coats or you will trap the moisture in the hull laminate instead of keeping it out. Letting the sanded hull sit all winter before painting in the spring is common.
I am planning to repair my barrier coat during a full winter haul out when I next need to re-paint the bottom, probably in 2-3 years.
Mark
