I have read many threads about leaking ports but thought I would add a specific thread about the 1983 30+ ports because the port frames are different.
When I purchased Discovery she was leaking in the usual locations with the usual results. To the right of the navigation table on the starboard side was always wet after a rain storm.
Previous fix:
In Discovery's case the previous owner used silicone to reseat the frames in the port openings.
Silicone was also applied to the glass and rubber seals.
Current status:
In removing the ports, I tried to do as little damage to the mahogany veneer as possible. Damage was inevitable due to the volume of silicone used to fill in and around the port to fill the gaps. Tools to remove port: ice pick, screw driver and wood wedges. Time to carefully remove port: 30 minutes
With the port removed, the silicone needed to be removed from the aluminum frame. Tools to remove port: ice pick, screw driver and metal brushes. Time to remove silicone from aluminum frame: 30 minutes
The port frame is held in place by 4 screws. After removing screws, a few minutes of twisting and pulling the frame caused the rubber gasket to pull free in one corner where it can be ripped out.
With the gasket removed, the remaining silicone was cleaned from the glass (tempered safety glass DOT 56 AS2-M.13 ANSI Z 87 1 1975) with a razor blade and acetone.
New Gasket;
I followed the advise from one of several threads and purchased a Catalina reseal kit.
url: http://www.catalinadirect.com/index.cfm?fuseaction=product.display&product_ID=1055&ParentCat=376
[h=1]Aluminum Window Reseal Kit C-25, C-27
Part #: E9020
Price: $98.49
Resealing Glass
I am currently waiting to receive the reseal kit.
I will continue this thread shortly.
Mark
[/h]
Previous fix:
Current status:
New Gasket;
Part #: E9020
Price: $98.49
Resealing Glass
Mark
[/h]
