tripper_dave
Anybody know if there are drawings available fo the ruddr for the 30-2?
Foss can make youa new one-they have the molds... Dennis Choate can rebuild your old one, and at the same time reshape it to improve handling and performance-and you won't need drawings for either options.
Do you need them for another purpose?
S
Dencho has done extensive work on my last two boats, and I can highly recommend Dennis and his guys, but if you don’t have deep pockets, you'd better set some limits up front.
A couple of quotes (paraphrased) from the man, or his man:</SPAN>
After seeing a 70 foot racer in the shop for a couple of months, I ask, ‘when you gonna be done with that boat?’ Dencho responds, 'When it leaves the yard.'
And a quote that doesn’t require parsing: 'every boat leaves here faster than when it arrived.'
I can attest to the truthfulness of both statements. Dencho is the best speed shop in SoCal. But don't think you'll get outta there cheap. These guys are used to dealing with big projects and budgets.
On the other hand, times are tough all over, especially for high end boat builders. So you might be able to work a deal...</SPAN>
Are there two companies using the name "foss"?
http://www.boatrudder.com/
This one sez that they have Ericson molds.
