I seem to have solved my intermittent starting problem. With everyone's input on this thread, I pulled the following connections and cleaned and sanded them. Then put a coat of electical contact corrosion protection on them.
Engine Harness
Engine ground cable
Fuel pump
Ignition switch
Solenoid connections
Start button
All of these showed some corrosion, with the fuel pump ground being the worse.
Engine has started first try ever since. I am thinking that it was the combination of a little corrosion in lots of places that was causing the issue.
Andy
'86 E-28
Engine Harness
Engine ground cable
Fuel pump
Ignition switch
Start button
Andy
'86 E-28
