Butyl tape can be helpful in removing butyl tape. Roll up some butyl in a ball and use it to remove the butyl off of the surface.
By the way: I'm becoming less and less a fan of the stuff. I've also concluded it's not the weapon of choice for bedding portlights. I'm here talking about the seal between the aluminum frame and the exterior cabin sides. I much prefer Sikaflex 291 for that task.
DOW 795 neutral cure silicone is probably the best product for sealing deadlights. It's what the kiwi boatbuilders use. I used it on all my portlights/deadlights back in 2020. Like Sika 291 (unlike 3m products) the bead is thick and stays where you put it, it was designed to seal glass to aluminum frames in highrise buildings. I used it to seal the aluminum frames to the cabinsides. Easy to use, if taped, the tape can be pulled before full cure leaving neatly coved edges. Very flexible, a trait needed on the cabinside of the E boats (they are qute thin and flex easily).
I found after removing all the portlights/deadlights that my aluminum farmed deadlights actually stiffened the cabinsides. During the process of fixing the portlight leaks, I bonded 4mm ply to 10mm boatbuilding foam and glued that to the inside of the cabinsides to remove the need for the alluminum fames to stiffen the cabinsides. The boat is better insulated now, and I'm less worried about leaks due to cabinside flex.
I believe I saw a post where Alan? Glued the fiberglass headliner to the cabinsides to help stiffen them. I would have done that, but instead opted to cut the fiberglass headliner out completely. Cinderella previously had cabin liner cut out in a big refit back in the 90's. When I bought her she was nearly a bare hull inside with PO adding reinforcement of the grid, and other key areas to prevent oil canning and stiffen her up.
Now I can see where the leaks were are coming from... Big job though, spent a week in a tyvek bunny suit cutting through fiberglass overhead with a grinder. Never want the pleasure of that experience again if I can help it.
Not all butyl is the same, ask me how I know, lol. I have not had luck with butyl, apparenty I bought a bad batch or something, has put me off from using it ever since. I hate redoing jobs I just did.
We recently had a look at Whidby 42 here we were considering moving up to. It was also done with butyl back in 2017 and lets just say we passed on the boat after seeing all the water damage from the leaks. Maybe everything just needs to be retightened after you cross an ocean with butyl since it relies on the fasteners to keep the seal?
