jreddington
On my '84 E-28 I have a Perko raw water strainer, model 493. I'm replacing the gaskets. The gaskets I'm removing are cork.
Checked the Perko catalog. They indicate use ONLY cork gaskets on "older style" strainers and use ONLY rubber gaskets on "newer style" strainers. However, they don't tell you what they mean by old vs. new either by year or some characteristic of the strainer.
Not sure if this strainer is original to the boat, or if not, when it was installed but it's been there with the cork gaskets since I've owned the boat the last nine years.
Have a new set of cork gaskets. However, as you can see in one of the pictures attached the gasket (like the old one) blocks a substantial part of the strainer outlet (looks like about half the area). I also notice the seating surface on the old gaskets seemed to be only along the outer edge with a lot of "extra" gasket hanging off towards the inside of the strainer. Should have taken a picture of this before removing the old gaskets. Shows up pretty clearly.
Does this mean I've got the wrong gaskets? Are the rubber ones narrower? Can't be fatal to water flow since the engine's been running with these all along.
Based on the attached pictures can you tell if I have a "new style" or "old style" strainer. Are there specific markings or other indications to tell new from old?
Have e-mailed Perko with this question but not yet heard back from them.
