You may also want to look at trying white Bounty (and only Bounty brand) paper towels. I know it may not be intuitive, but I've had good luck tacking things down with them. No dye, as lint/dust free as anything I've found. You can get a couple wipes out of each piece, folding as you go to always have a clean surface, and then toss it and get the next one. Obviously, try a test spot. I've not used them with Perfection.
Also, if you do attempt any polishing after the fact, make sure you are at the right point in the cure process. I don't know this product first hand, but have worked with products where you had an ideal window to work in. Too early and it's too soft. Too late and it's too hard. This is one I'd hit the Interlux rep up for help on. Same with applying a wax. Not all topcoats will like that. Awlgrip is one of these odd products that develops the gloss on the surface, which is why you can't buff it out like other paints. Just make sure Perfection isn't something like this before you abrade the top surface.
