c.gustafson
Hello, Mates. This last weekend, I started the process of changing the oil on my Universal M40 ('87 Ericson 38-200). I have a Jabsco oil change pump that I use to remove the old oil by inserting the clear plastic tube down the opening where the oil dip stick goes. The problem I ran into is that I only got about 4-5 quarts of oil out of the oil pan. I initially inserted the plastic tube about the same length/depth as the oil dip stick -- and then when the oil stopped flowing, I tried a little deeper but didn't seem to result in more oil being sucked out. When I put the oil dip stick back in, the dipstick shows that there is still oil. Any words of wisdom on what I'm doing wrong? Must be something simple that I'm missing. As always, many thanks for your assistance.
