Tie Rod....
Mark,
If your boat came with an attachment for a "tie rod" (that's the name N. A. Robert Perry gives it), you should put one back there.
Our Olson 34 has one. Ours goes from a slot on the mast up a couple of feet to a SS eye strap in the cabin top just behind the collar that carries the halyard loads, and has a turnbuckle.
You see this little bit of standing rigging on most all boats with keel-stepped masts. It has nothing to do with shroud loads, AFAIK.
Some Ericsons have it going down to the alloy mast step, in parrallel with the spar on the inside.
Note that when you load up the main and genny/spinnaker halyards with hundreds of # force against the turning blocks on the collar, this can lift the cabin roof a little bit where the mast passes thru it. Your housetop mainsheet also has a 90 degree turn at that collar, as does the vang line led aft.
I should note that some other makes of boats have had aluminum collars with provision for thru-pinning of the spar, to solve the same "lifting" problem.
