Weekend projects
Shannon,
Is your new pump for the pressure water system, or a fresh or raw water pump for the engine? What kind of pump did you buy and where did you get it at a reasonable price in these days of supply chain delays?
Fresh water pressure water system. Picked it up at trotac for $169. I saw one on sale for 160 at binnacle, but it was close and they had what we needed. It is a Jabsco 3 gal per min. It works great!
I successfully removed the old marine head, hoses and holding tank this weekend. Feeling very sore, yet also very happy with myself.
I bet! My husband finished that job with a number of bruises! It is a job to be thankful for once it is over!
We just installed new pumps , new faucets.
Redid the headliner, ceilings, and sides
and are also painting the deck ans cabin
Forgot to mention we’re restoring a kenyon alcohol stove hah
Not so much ”weekend projects” but rather “winter projects”….upgraded the traveler ( https://ericsonyachts.org/ie/ubs/mainsheet-traveler-upgrade.961/ ) and installed a new manual windlass. Blog on that to come.
View attachment 42278View attachment 42277
Looks great!
Are you also replacing water lines while doing the sole? This is definitely on my list.
Well, I wasn't planning on replacing the water lines. But you're the second person to ask about that. *Lonnnng sigh* As other people have remarked, every time we dig in to fix one thing, three more pop up that need attention. We only got the boat last fall, but we seemed to have pressure from all tanks. Our list is so long that my inclination is, if it works, don't fix it. But . . .
Did you mean your list included the sole and water lines, or just water lines? Why was that on your list?
When I replaced almost of the OEM "Qest" tubing, I was able to pull the new tubing thru the bilge sections and then just put some securing places where I could get at them with the sole access panels set aside. While we temporarily have all of the sole pieces temporarily home for refinishing, you can see the bundled tubes and wiring. They go clear across, but are only secured in the center part where I could get at them via the lift-out panels.
I hear you. The first year (and second and third), we did so many projects. The key is to do what you need to make the boat function without taking away from being able to use it. We were out sailing 100 days in our first year (some evenings only a couple hours) and have been using the boat for the past three years and the sole could be done, the water lines changed, and so many other projects... But first we sail.
If we do the sole, we will likely change the water lines at the same time just because we will have better access and they are likely as old as the boat. Unless, the sole is easy to remove again to replace down the road (which would be a great way of coming back to it when you have time).
Project creep on boat projects is a real thing!!!! We just try to not let it interfere with sailing.
Water lines, bilge pump hoses, transducer cables, and even DC wiring might be strung through areas accessible only with the sole removed.
I think the answer is to install a removable sole rather than to preemptively replace everything running through it, all in one shot.
Tin Kicker
Just did all new thru-hulls with hoses, started on a solar package, lady is deep cleaning and teak oiling the interior, . . .
Today was Day #2 of bottom sanding and at the end of the day made a find worth sharing. Yesterday bought some STAR-BRITE Easy on-off hull cleaner and at the end of today when everybody had gone home, tried it for the first time.
For scum lines it works better than anything I've come across and worth the price for that alone.
BUT
It turns out that the run-off softened the bottom paint so much I could remove a lot of it with a plastic chisel (Harbor Freight). Spritzed on the hull cleaner and the shadows of remnant barnacle material started to foam away. Waited and used a scrub brush on the bottom paint - and the scrub brush was clearly softening bottom paint which made it much easier to scrape or sand.
And of course - Do NOT use this stuff AFTER putting on fresh ablative bottom paint.
Ben Romano
I did the same.
Would love to hear anything you learned in the process/tips/pitfals, etc. I'm planning to remove all of that in my 1978 E-27 and replace it with a port-a-potty. I'm particularly concerned about what to do with the thru-hull(s) that are part of the system, and whether I can even do this with the boat in the water. If the thru-hulls are in good working order, are they safe to be left in the closed position once the hoses are disconnected, with some kind of end cap on them perhaps?
Please start a new thread for your head replacement/ options project. A specific title will reach more members and also make the thread more easily searchable for others.
We have some blog entries on heads, but the blogs are sort of a jumble at the moment. https://ericsonyachts.org/ie/ubs/replacing-the-sanitation-system.230/
By the way, "Weekend Projects," as this thread is called, is not a very useful title. Too general.
This, in my opinion is the way to go. Just as we often say 'don't use 5200 on anything you will ever want to take apart', we should think that if we must take something apart, we should put it back so it will be easier to take apart next time.
If you read thru the earlier massive cabin sole thread, you will note that many of us have changed to exposed flush fastenings and our cabin sole sections are easily removable. Matter of fact all 8 pieces of ours are at home now getting multiple coats of varnish.
Reference: https://ericsonyachts.org/ie/threads/removal-of-glued-down-cabin-sole-master-thread.1526/
Based on what all of you have said, we'll make the sole removable. Since there seems to be some interest, I'm starting a new thread.
Thanks!
nquigley
Projects seem to be going backward on me - stuff breaking faster than I can go forward. Trying to alternate house/boat/paid projects. But weather/customers/dogs/squirrels/woodpeckers/entropy are all working against me.
For the boat: noticed today that the fenders got squeezed out during one of this weeks blustery days and the edge of the dock (though padded) rubbed through the paint (again.) And the wind instrument atop the mast appears to be loose. Next calm morning (maybe Wednesday?) I need to go up and down the mast and check every tang, pin, screw, and bolt. Before leaving the dock again. The problem is that calm spring mornings are also frosty mornings.
Your post makes me think of this anecdote I saw on line this week ... everything on your boat is broken - you just don't know it yet.
