Hi Gareth,
I have not tried this, but it is based on my ice box. The prior owner put a thin e.g. 1/2" thick layer of foam insulation on the upper half of the inside. Looks like he glued it to the fiberglass. I had initially contemplated removing it, but Emerald has a dark green hull, and based on the temperatures when I've opened the hanging locker door in the winter time, I am thinking this insulation is badly needed. What I've decided to do is coat it with epoxy resin. I am pretty sure it won't eat the foam, but I will do a tiny test corner first. Something like this might be something you could try in non visual areas. My biggest concern would be creating a moisture trap. I think that's where the epoxy coating might work.
I've attached a picture I just happened to have of the inside of my icebox.
BTW, if anyone has first hand experience that this is a knucklehead idea, please say so! This is merely how I am figuring I am going to deal with my ice box and an existing situation, and thought it could be replicated on a larger scale
-David
Independence 31
Emerald
