CorrectNo clue that it had even happened?
Happened to me when our boat was around 10 years old (‘83).
Our prop didn’t strike the hull or break but obviously the cracked strut had to be replaced. It’s a lot of work to chip and grind away the glass to get to the encased base yet isn’t as bad a job as it sounds our you would think.
Hopefully you’ve got a place where you can do your own work to avoid the high labor costs.
Good luck!!!
This isn't my boat, it's a customer's boat.
Oops! ))This isn't my boat, it's a customer's boat.
There is hope! Marine Hardware in Washington apparently has many of the strut patterns for Ericsons. They had one for my 30+ which turned out to be very close to the original. Link to blog about replacing the strut: https://ericsonyachts.org/ie/ubs/1984-e30-strut-replacement-part-1.471/If this owner checks in here, I would imagine that his question will be about where, after all these years, to find a duplicate casting. This comes up regularly regarding a source for struts for boats built long ago, and usually the plug for the casting is long gone, too. Heck, the foundry might be gone too... (sigh)
I wonder about that, too.Seems to me when the strut goes and the prop hits the hull and breaks a blade, the shaft becomes a pretzel.
Surprised the boat got back to the slip.
Or maybe he did know something was up and used the cleaning service instead of a haul out.
I am thinking that a bronze prop (or any other part) is highly unlikely to just break off. I could imagine it bending if it strikes something like a dead head, but shearing off like that would cause me to inspect all the pieces once the boat is on the hard for "dezincification" to observe if the broken parts are turning pink. Once a bronze part gets attacked by electrolysis, it gets really weak.
As the saying goes: "Good Grief" !!The strut was broken when we dived this boat for the previous owner last year. Based on the overall lack of maintenance, dezincification of the prop and strut is highly likely and probably why both parts were damaged.
