gene faley
I have a '76 29' Erickson. In the last few years I have noticed some spider-cracks in the rudder. I assume this may mean that I have some moisture in the rudder. There has been no rudder damage in the 6 years I have owned the boat. My course of attack is to drill a small hole up from the bottom of the rudder (done). Then this coming spring I will route each crack with a dremel router using a 'v' router bit. I'm not sure what to fill the router crease with. These cracks seem to be more plentiful on the starboard side of the rudder; they are locate mostly on the upper half to one-third of the rudder. Is my approach appropriate? Suggestions for compounds to use to fill. This boat resides on Lkae Erie and is in dry dock; covered in the winter.
Thanks, Gene
Thanks, Gene
