rub rail and mast removal E27
Status
Not open for further replies.
pcb don
I'll be pulling my '76' E27' from the water shortly and will need to pull the mast. Does the mast support sit above the deck or does the mast sit below the deck? The only fastner is a slotted screw in the slot at the rear of the mast. Also is there an electrical disconnect in the mast? If so how much play is there for the wires?
I'll be replacing the rub rail as my wood rail is damaged. Does anyone know of appropriate replacements? Still considering repairing the existing but there are a lot of gaps between the hull and the rail.
I picked her up last Oct and now she's become my 'project'. I've stripped the inside of everything except the main bulkhead and will be refinishing all the wood,etc. The interior gelcoat has yellow stains and from what I've read it appears the best solution is to use bleach, any other ideas? Thanks
Don
Status
