Outhaul Project
Went down to the boat this weekend with tackling the outhaul project and a couple of other lesser feats in mind. After asking the group what was involved I felt sure it would be a half hour project. A mitigating factor in this particular project was the weather conditions; well below freezing with a steady 20 to 25 mph wind, with a snow squall thrown in now and then for effect.
I tied a messenger line to the line coming out of the boom and stared pulling on the outhaul at the boom end. The fit where the line enters the boom is tight as it goes through a turning sheave and a clutch and finally the hole in the goose neck assembly. After forcing the line with the messenger through all this I got 7 or 8 feet and all stopped. Spent the next 20 minutes trying to get the line back out through the goose neck because everything was so tight. I decided that the problem was the thickness of the line, so if I taped a messenger to the wire end this would not be a problem. About this time I was joined by a friend who when the messenger line became stuck again he decided all it needed was a bit more force which promptly parted the messenger line from the wire well inside the boom. Shock shown in our frozen faces. A look into the boom with a flash light from the aft end showed nothing but numerous lines and 18 years of aborted attempts at bird nesting. It was quickly decided that the boom had to come off and into my friends garage where frostbite was less of an issue.
At the garage and after a liquid warm up, both ends of the boom where removed along with about 5 lbs. of nesting material and the reasons for our inability to do this with messenger lines became apparent. I expected a wire to rope line situation run through blocks inside the boom. What I found was the line tied off on the through bolt at the end of the boom just in front of the boom fitting, that ran through a block with a becket and a fiddle block. The wire was attached to the becket, no messenger line would have ever worked. We also found that the line used was too large for the sheaves in the blocks and the old line with the tape and the messenger could not clear the body of the block. Also the turning sheave in the boom where the wire leaves the boom was frozen. After rereading the posts on this I realized I had been told this set up might be the case.
My friend decided that I not only needed a new length of wire, but new blocks and while we where at it, new line of the right size and long enough to be led back to the cockpit though the new rope clutches he made me buy at the boat show. Oh, and new reefing lines since it was all apart, I had bought new rope clutches and I should be doing it right.
Off to the local WM where we are well know to the local sales staff, who where bored because you could hardly see across the street for the snow squalls so the place was empty and they promptly set us up with a length of wire from the left over bin. For the cost of the compression fittings we had the wire. Over to the rope department where a 48 ft. length of 5/16 was found in the left over bin which we got the SPECIAL DEAL on. I have a Port Supply card so the two new Lewmar blocks where about 40% off and the reefing line was 30% off. In my frenzy, and since I had to take my main sheet off to do all of this anyway, I brought that in and had them send it out to put a Flemish eye on the one end to remove the bowline connection at the block uniting the main sheet to the traveler. All told I was out of there for for just over a $100.00. Not bad.
Everything went together in a flash now that we understood how it all worked and the boom with all its new line, new blocks and lubricated turning sheave is back on the mast and looking spiffy.
I guess the best advise I can give to anyone attempting this project is to take the time to take the boom off the mast and remove both end boom fittings and as Loren said, "all will be revealed."
Next: Change the traveler cars from Schaefer to Garhauer
