GPS/Fishfinder combo
The fathometer on my E-29 just gave up the ghost, I think that it was original equipment, so I started my search for replacement. I found a couple of deals but in order to have them installed I was going to have to haul the boat and pay for installation. The more that I researched the more that I started finding people that were using fishfinders with transducers that mounted inside of the hull. A good color finder is not cheap and you have to buy the transducer seperately. The difference between the cost of a good color finder and a cheaper digital sounder was quickly made up by the cost of the haul/installation. With the cost of a good GPS being what they are, I found that the combination unit was somewhat cheaper than buying both units seperately. West Marine, in their new 2006 catalog, has a Garmin 498 ( I think) that has a lot of features, newest chart technology, and the unit can either be mounted on the enclosed bracket or can be mounted flat. It comes with all of the coastal charts for the US, including Alaska and Hawaii, and accepts chips for any other areas that you may want to add and the depth is sounded down to 900', plus, if you want to catch fish you can actually use it for what is was designed for. The cost for this unit is $1000.00 but that includes an external ant. for the GPS and the transducer. Want good gear then you have to pay for it. As for mounting, I'm going to simply remove the old fathometer, 3" round, cut out the template and then mount it flat on the port side cabin face. I have a tiller on my boat so access and seeing it will be very easy for me.
