The attached photo's are from an Ericson 28+ that I just purchased. After seeing that their was some green on a bunch of metals, I automatically knew some grounding/bonding was not happening correctly. After looking around in the engine compartment, I identified that the green wire coming out from the Ericson AC Box was frayed on the end, and not connected on the other end. I believe it is either an Atomic 5411 or 12HP version.
Can anyone point me to where this other end should be connected? Most presumable somewhere on the engine block to complete the grounding plane. Thanks.
