FullTilt E28
So my wife and I just bought a really nice E28 - it came with an older telescoping whisker pole. I know how to use the whisker pole - but this pole is adjustable the outer tube has holes for what I would presume is a spring loaded type button to lock it in various lengths etc. This appears to be missing - I haven't pulled it appart yet - my best guess is that the two sections will easily seperate or in this case one end could easily slide out and end up on the bottom of the bay. To add to the challenge this pole weighs about 5X as much as any spinnaker pole I've delt with as foredeck which doesn't make it any easier to handle.
Anyone know how these old whisker poles should work? Can they be set up with some type of line system for both adusting the length and locking it so both sections stay together?
I'll probably rig something up so we can use our extra halyard as a make shift topping lift. The whisker pole is so heavy it slides down the jib sheet when hooked to the jib sheets - clip it to the jib ring directly works OK but in light air it pulls the jib down and screws up the jib shape.
Any ideas or thoughts around how to make this existing pole work would be great. Not really interested in picking up a new one -given we'll probably get a spinnaker pole and gear for the boat eventually.
