I am pretty meticulous in the care and maintenance of our 1984 E30+ boat. As I was walking forward on the starboard side I noticed a new creaking noise about two feet forward of the shrouds right where the deck joins with the vertical section of the cabin top. It sounds like two pieces of wood rubbing against each other. The noise does not occur if I step closer to the toe rail. The deck does not feel soft or spongy and there are no deck fittings in that area for moisture to get in, so I don't think it's that.
I can also create the same sound in the same location by steping hard on the cabin top just forward of the mast, so I think by doing that I am stressing the same section that is making the noise.
I thought it might be the interior trim in the V-berth just forward of the hanging locker, as there are several pieces that come together at that point. I tried spraying in the joints of these pieces with McLube dry lubricant, but that didn't make any difference.
I also thought that maybe the rig was a bit out of tune perhaps putting stresses in new areas of the deck, so I did a complete re-tune from scratch, again without any impact on that noise. I think the tuning is pretty good, as I ended up very close to the same results from my last tune, without comparing until I was finished. The cap shrouds feel quite tight and are at about 15%, lower shrouds just very slightly less and intermediates very slightly less than that. The mast track looks straight. The tie rods had been adjusted last time before I tuned the rig and have not been touched/changed since then, so should still be correct.
There is no noticeable change in the doors of the hanging locker or in the way the head door closes (ie. it's not binding or showing any sign of movement). The area under the mast step on top of the compression post had been professionally reinforced with a steel plate several years ago by a previous owner and has been stable ever since, as far as I can tell. There is no sign of anything having changed, except that there is a new noise where there was none a month ago. I am very sure that the noise is new, as I know this boat very well.
Does anyone have any ideas as to what could be making this noise? Has anyone encountered a similar noise in a similar location? I know that boats are under alot of stress from rigging, wave action, etc. so I know they are a dynamic, changing structure; I just don't like things I don't understand, or that could represent a potential problem.
Thanks for any suggestions or advice.
