why the copper?
I don't really see any advantage to running the copper wire inside the mast. A) Aluminum is an excellent conductor of electricity and you have lots of it available.
B) The voltages you will experience with a lightening strike will seek the shortest path to earth (ground) regardless of conductor type.
C) The dissimilar materials (copper/alum) will create a lot of corrosion where they meet.
Of the boats around here (Michigan) that have been hit by lightening usually only loose their electronics. I've read enough to decide that none of the experts can definitvely give you a foolproof method to avoid/minimize a lightening strike. They ALL will admit (in the fine print) that there is little you can do if it's really big lightening bolt. Your two options are to try to not make yourself a target (no grounding) or to try to bleed off the potential to try to avoid a hit (lightening grounding). Both methods work sometimes.
The surest thing is to buy good insurance and pray when it storms! BTW, I like internal halyards. Keeps the sun off half the halyard & when run to the pulpit a really easy way to stop halyard slap (I hated bungee cords!!!). Some of the older masts had sponges stuffed up inside to stop the wiring from slapping. You may need to fish them out to run your conduit & drop your new halyards. Makes a professional looking install though, IMHO.
Have fun & sail fast
Bud E34 "Escapade"
Bud E34 "Escapade"
