I have a "new to me" 1985 E26. Overall, she's in absolutely stunning condition. Plus, I've been upgrading or replacing many of the systems so that she is as close to a "new" boat as is reasonably possible.
Now, I'm starting to drive myself crazy...
After a week in the pouring rain, I'll collect about 3/4 of a cup of fresh water behind the engine which I've traced to the cockpit locker, and a drop or two (literally) from the hull to deck joint at the corner where the transom meets the starboard side. I've tried to fix the cockpit locker by applying some closed-cell foam weather stripping to the ridge where the cockpit locker door rests.
My sliding window in the head (a Bomar, I think) admits a few drops. Above that, I'll have a very small drip where the headliner meets the teak. I'm almost certain that this leak originates at the mast, where the electrical cables and VHF antena enter through the deck. After a week in the pouring rain, I can easily mop up the water with a single shop towel (it conveniently pools around the drain in the head sink, which is slightly raised above the contour of the sink basin). The teak looks perfect, by the way, and I'm reasonably sure that water is not travelling in any other direction.
From the posts here, it seems that many have zero tolerance for any leaks whatsoever. Should I have zero tolerance for the leaks described above? Should I be alarmed? Am I over reacting?
Just looking for a point of reference here...
