sailingdeacon
Sorry if this has been asked, I could not find it. My engine noise is louder than in previous years. This only occurs at idle. With an increase in rpms there is little noise. Could it be that the exhaust riser arm is becoming clogged where the water comes in but with increased rpms more water is forced through it? Water pump impeller is OK.
A second symptom is that the rpms under load is about 300 rpms lower than in previous times. I get full rpms without any load.
At idle, water is coming out the exhaust but I cant tell if it is a normal flow.
Engine is an M35 4 cyl Universal with a water lift muffler fresh water cooled engine.
Engine does not overheat.
Does an increased exhaust noise indicate
