Sven
Seglare
I've been reading the rudder mod thread with some interest.
When I first saw Lew's post about Serendipity I sought out the spec sheets and admired the line drawings. I really liked the modified keel and skeg-hung rudder ... cruising course-keeping and kindly motion at sea coupled with the need for performance.
I also looked at the prop location and direction and the rudder and thought that is all good as long as you are going forward. In reverse I could not imagine how the design would work until you built up a head of steam.
During our post sale sail (the courtesy run with Lew, ever the gentleman) I spent a lot of time obsessing on going backwards to buoys. After many attempts to back up to a buoy I finally got close enough (not under directional control) to just declare victory.
Since then Nancy and I have spent more time backing up to buoys (right in front of the CG station !!) over and over again and I think I'm ready to admit defeat
I can not control our beautiful E39-B in reverse until we are moving.
Knowing that limitation is part of the solution.
The final straw was when we finally went to the fuel dock to fill up (Lew didn't want to do that earlier because we'd just end up with aging fuel) as we hoped the weather would clear and if nothing else we could power up to Catalina or Santa Barbara Island about 70-100 NM away. The lady does what she wants to in reverse ... as expected from the drawings Pam King sent us !!!
We put enough fuel in the tank to get us back even if we had to power both ways.
To make sure we were in some state of control I set up he spring lines to let us restrict where we would go and make sure we wouldn't go in the opposite direction. I moved the fenders in anticipation of needing them further aft as the spring lines would pull us around.
Amazing, the spring lines never even got tight ! The stern just walked to port as I was backing up. Fortunately, the fender was far enough aft to keep the hull from hitting the corner of the dock.
Lesson learned. Lines and spring lines will always be in place from now on because this lady will go where she wants to when backing up.
Would a bigger/deeper rudder help ? Maybe, so we're watching the thread on rudder upgrades.
Did any of you read the WWII story about the tug (mine dropper ?) where the essence of the whole story was the prop walk and how that lead to the dropped depth charge ? I appreciate that novel so much more right now.
Happy New Year to all and thanks for all the help.
-Sven
-Sven
