Florida 1988 Ericson E-38-200 For Sale
skywalker
  • 38' Ericson Ericson 38-200
I'm listing our boat here first until Monday Feb 14th then will be posting public
Year: 1988
Asking Price: $45,000
Located in Port Charlotte, Florida
Hull Material: Fiberglass
Engine/Fuel Type: Single Diesel
YW# 5106-1956526
Just listed. Lots of upgrades.
New cabin cushions
Cabin sole refinished
Main cabin port light seals changed
Rebuilt injector pump in 2018
New dripless shaft seal
All head hoses replaced 2020
Manual head with holding tank rebuilt 2022
New exhaust riser and elbow 2020
All galley water hoses replaced 2020
New sink faucet
New Manual Foot pump freshwater
Dual Racor fuel filter bypass system
Great sails, spinnaker, lazy jacks, whisker pole that stores on the mast
Please note that I suggest new rigging.
Additional Specs, Equipment and Information:
LOA: 38' LWL: 30' 6" Beam: 12'
Displacement: 15500 Draft: 4' 11" Ballast: 6300 lbs
Fuel: 55 gal Water: 80 gal
Fold up dinghy and 6 HP outboard and tank
Engine Lift
Sails:
New North Sails cruising spinnaker with snuffer
UK full batten main
New Hall Rigid Quick Vang vang in 2000
Mast mounted adjustable whisker pole
3 genoas
Harken roller furling
Harken Batt Car system
Harken lazy jacks
Hydraulic backstay adjuster
Aluminum double spreader spar stepped on keel
Mainsheet traveler
VHF Radio with DSC and MMSI 2007 Standard Horizon Ram+ Command Helm Microphone with DSC
New Marine Jenson stereo with cabin and cockpit speakers
Electrical and Mechanical
Isotherm Compact Refrigeration System in 2008
Inboard Universal diesel engine 32HP fresh water cooled
New Engine Motor Mounts in 2007
Fireboy Xintex Propane Sensor System in 2008
54 gallon fuel tank with fuel shut of valve
Manual bilge pump
Electric automatic bilge pump
Bilge blower
Fuel shut off valve for propane system
Fume detector new in 2008
2 Batteries in 2 bank system with switch
Automatic Battery Charger
Dual 30 amp shorepower inlets
Dockside electrical cables 12V and 110V
Deck & Hull
Wing keel shoal draft design
Fairwinds Canvas Dodger, Bimini with Connector, Sail and Pedestal / Wheel Cover
Maxi 3-Blade 16 x11 feathering Prop
Rocna Anchor with chain and rode
Fortress Back Up Anchor w/ Chain & Line Anchor Rode
Lewmar windlass
Anchor locker on foredeck
Teak cockpit table revarnished 2022
Edson pedestal steering with engine controls
Fenders and lines
Double lifelines with port and starboard gates
White fiberglass deck with grey nonskid
Navigation lights
Spreader lights
Fold down S.S. Swim ladder
skywalker
As requested here is some more photo's
Shawn Rodel
38-200 West coast FL.
Yes it is a beautiful boat, we are just up the coast from you New Port Richey. We have #274 88 38-200
William K
Hello, Skywalker - is Endeavour still available for sale? You can reach me at wmfk@aol.com if she is. I'm looking for an E38 or E380 and Endeavour looks pretty. I wonder if you ever fixed the sole puddling at the base of the mast? Thanks!
skywalker
The water drains down the mast and into the bilge where it gets pumped out. When I had the sole redone a groove was cut into the 2 halves that circle the base and now the water drains straight in. I also epoxied the bottom of those 2 halves.
Mainessailor
Year: 1988
YW# 5106-1956526
New cabin cushions
New sink faucet
Engine Lift
Sails:
UK full batten main
3 genoas
Harken lazy jacks
Mainsheet traveler
Manual bilge pump
Bilge blower
Deck & Hull
Lewmar windlass
Fenders and lines
Navigation lights
Spreader lights
Hi is there any chance you could tell me where you got the replacement seals for the portlights?
Ours are shot on my E-38-200
I’m in port Charlotte BTW
He has not checked in since Oct. 2022. Best use the site messaging scheme. Just click on his site name, click on Start Conversation, and send a message. Given that his former boat was an '88, it may have had the same Lewmar opening ports as our boat. A friend of mine installed all new rubber seals on his (same) ports in an '86 E-38. Lot of work, it was. I chose to replace all of ours in 2021 with new ones. I believe that they are much improved in design. Of course, YMMV.
Lots of opening-port threads on this site, some searching will net you a ton of relevant reading and solutions to ponder. There are some pix of our new ones in place in my blog, FWIW.
Happy holidays,
