Dry Glazing with Vinyl Channel
I have yet to remove all my frames and strip the old paint and reassemble, but I feel confident this will be a long term solution, not just a band-aid. As a mechanical engineer, I have product design experience in many technologies, not so much in glass glazing - dry or wet.
This is a very straightforward solution with no special techniques: 1-remove the parts, 2-clean the parts, 3-assemble the parts, and (from what I've read on other portlight repairs with channel dry glazing) 4-apply a small silicone wet glazing bead on the outside between the glass and the vinyl glazing.
from a post on another thread...
My portlights needed refinishing and reglazing. In my attempts to find a new extruded vinyl to reglaze the portlight, every website I found, the glazing channel was too small. My next choice was to bed the DSB glass with butyl tape and rubber spline. I was not exactly sure which spline to get because of the unknown squeeze factor.
I eventually found what I believe to be the right sized glazing channel for an E25+ 1980 fixed portlight. It is part number
P-8174 from Prime-Line. You can't buy it direct, but Home Depot will special order 100' (min buy) for $20. Based on what little I know about o-rings and seals, this extruded glazing should be a low maintenance solution for many years.
Portlight aluminum extrusion frame channel = .342 wide X .410 deep
http://www.primeline.net/home4.wcs?c...1&cItem=P+8174
