I am considering an Ericson 23 as my first sailboat. I am seriously considering getting a professional survey, but I'm doing the initial surveys myself. I've read Don Casy's "Inspecting an Aging Sailboat" five times over and now I'm out looking at boats... and full of newbie questions.
1-On an e23 Mk 1 I noticed that the keel bolts were 'uncovered'/'uncoated' and rusty. Is this normal? Sound? Any reason for concern?
2-How should the e23 hull/ keel joint look when the boats on the hard. I assume this area holds the potential for leaks. (???) One Mk-1 I looked at felt like it a had a ridge of some filler material/ calking running along the joint under the paint. (next time I'll bring a camera.)
3-I also noticed that the fiberglass interior of the Mk-1 doesn't give much access to the hull nor does it provide much storage. Is the Mk-2 better in this regard? Are there problem areas on the hull/deck joint? Where is the best place to inspect the hull/deck joint of a Mk1?
4-One mk1 had an adjustable outboard bracket bolted on below the normal outboard 'cutout' in the transom. Is there a problem with the stock location? Is it particularly weak or difficult location. Any ideas why someone would do this?
5-Anything unique to the e23 I should watch out for? Any gotcha's?
I have many more more questions but I'll stop here.... Any advice or nudges in the right direction would be GREATLY APPRECIATED!
Thanks!
Jason
Thanks!
Jason
