ChrisS
I'm hauling my boat in a couple of weeks, and I have a failing wooden backing block on one of my two 1.25" cockpit drain thu hulls. Both look to be original, and they are not proper seacocks, but inline valves threaded to the mushroom head thru hulls. I have decided to replace the two thru hulls and install proper seacocks. The Compass marine site has a great tutorial about this.
If memory serves, the thru hull fittings on the outside of the hulls were flush to the hull.
My question: in looking at various brands of thru hulls, I see that most are not flush fitting, but mushroom shaped. Once I remove the old thru hulls, how to I fair the surface to be able to have a tight fit if I cannot find the exact same thu hulls?
