Davis Wind Scoop
ron7546
When I bought "Blue Note" a wind scoop was included but no instructions.On the Davis site I found some info and it refered to dowels and screw eyes,none of which I have with the "scoop".So, what do I need and how do they rig to the scoop and thru the hatch.
Thanks in advance
Ron
"BLue Note"
Shadowfax
First off, are you sure you have a Davis wind scoop, or do you have a Breeze Booster. The Breeze Booster is self supporting. If you indeed have a wind scoop, see if there is a pocket at the bottom back of the scoop to insert the dowel into. If found get a dowel longer then your hatch opening, insert into the pocket and dowel will act as the stop. There should be a grommet at the end of each of the wings. Screw in a couple of cup hooks, or the like, into the hatch trim and hook the wings via the grommets into the cup hooks. The top of the scoop is usually held up with the jib halyard or a line to the head stay .
The value of the self supporting Breeze Booster is obvious if you find you need to buy something new.
Enjoy
treilley
A Breeze Booster came with our boat and I used it for the first time a few weeks ago. It worked great. It is self supporting and easy to install.
