Hello folks-
I have just gotten my new main (with 3 reefs, joy!) and cut-down jib (now 90%).
The sail has a cunningham grommet... I used to use the cunningham on J24's, but for the Ericson (E34 style rig) I could just use halyard tension...
I am thinking of setting up the cunningham, though, and would appreciate any comment.
- Specifically, what purchase would I need for an E34 / E35? On the web I see comments from 4:1 on up to 12:1.
- What load an I looking at (affects line, block sizes)
- While I'm at it, any thoughts on a new halyard are welcome. Absent other advice, I am planning to get 3/8 dyneema (ease on hands and better likely compatibility with clutches and self-tailers.)
I am unlikely to do 12:1 on the cunningham. 4:1 seems civilized in terms of size (and could be 8:1 if I run it through the grommet and down to the boom... which I would prefer not to do, but might if I've got sunk cost and 4:1 doesn't work). I am imagining something I adjust only rarely (once or twice per sail, unless the wind changes a lot)... probably using a cam-on-the-final-block rig (like on a dinghy mainsheet) that I have to go forward to adjust. Already have a lot of lines running back to the cockpit, don't feel the need to add another unless advised very strongly to do that.
Any advice appreciated.
PS:
This is a follow-on to my earlier post re: sail trim, linked here, but since it is about the cunningham specifically I thought I'd start a new thread:
For those of you that kindly responded to my weather helm post, it was very much appreciated and with the new main I can start applying your advice.
I have already seen the (very helpful) thread here:
while I agree re: backstay adjustment, my boat has a split backstay and no adjuster... and I am not sure how I'd even add one given the split backstay. So no backstay adjustment for me, it seems. And it was unclear from the thread what purchase/load I need for an E34.
Halyards are also discussed here:
PS:
Weather helm / helm balance question
How do you (personally -- looking for your experience with your Ericson) adjust your helm balance? Also, roughly how much weather helm is acceptable/normal for Ericson's (and at what angle of heel)? I am finding 1-2 spokes worth almost always; Raymarine wheel-pilot starts struggling with...
ericsonyachts.org
Rigging a Cunningham
I have a 1983 E28+ that has no Cunningham. I would like to rig one and have seen what looks like some pretty good examples on the Harken web site. Any suggestions on what works well? One concern is using a Cunningham hook vs just threading a line through the Cunningham grommet in the sail...
ericsonyachts.org
35-3 Halyards
I’m looking at new halyards for my 35-3. The data I’ve found shows 3/8”, but I’ve got a mix (3/8” on the main and 7/16” on the headsail) now. Has anyone had issues with going to 7/16” for both the main and headsail? The deck hardware can handle up to 7/16”, but I’m concerned about the mast head...
ericsonyachts.org
Sourcing a new main halyard
Recently removed the old wire-to-rope main halyard on my 32-3, and looking for an all-rope replacement. Wanted to use 10mm (3/8) New England VPC, for which Defender (at 1.42/ft) is about the only show in town. West Marine is pricey, Fisheries doesn't carry, Vela Sailing is out of stock, APS is...
ericsonyachts.org
