sailingdeacon
I have no leaks but want to know the construction design of the cabin top and side decks of my '87 E34. Previous boats always were of a sandwich design with balsa or plywood inside, so that a leak from any fitting could slowly cause rot. The E34 has a full vinyl liner with zippers. When I take a look under the vinyl, I see sheets of foam and rough fiberglass behind that, so that, except for a very few places, there appears to be no sandwiched material to rot. Even at the point of cabin top winch mounting, there it is solid fiberglass. Am I seeing this correctly? If so the likelihood of rot and delamination is almost nill.
