Alan Clendinen
Can someone please tell me what the bridge clearance is for a 1987 Ericson 35 MkIII? We're trying to see if we can take her through the Cross Florida Barge Canal/Okeechobee Waterway.
The mast height above the water line on the 1987 E-34 is 51'. The mast height above the cabin top is 46'. Based on the specs for the 82 E-35 the rig specs are the same as the 87 E-34. From what I have heard about the Okachobee is that there is a company that will strap barels to the side of you boat and fill them causing a controled heel of the boat allowing you to pass under the low bridges. I am in the planning stages of doing the same trip. I will find out tomorow if this is actualy the case and let you know.
Andy
Alan,
I suggest that you need some empirical evidence...
You know, Real World info.
Tie the end of your hundred-foot tape you bought on the cheap at Harbor Freight to a mast head halyard shackle, and then tie a 60 fot retrieval line to the shackle in case the tape end comes loose.
Hoist to top. Estimate additional to allow end of roll to reach the water, secure it at that point and ease it over the side to the water level.
Add feet as appropriate to allow for additional height above halyard sheave, like the mast head fitting and antenna/wind transducer. You can usually step back on the dock somewhere and eye ball the top additional distance with your $200. binoculars that you bought on sale (been there, done that!).
Write this clearance number down in large numbers and tape it to the nav. table...
Once all this work is done and the halyard is restored to stowed position, open up a bottle of Pyramid - Hefeweizen and relax!
Best,
LB
ps: this procedure usually does not invoke the Heisenberg uncertainty principle...
:nerd:
I am often wrong, but I was not aware of any 35-3's with a rig taller than the 46' I, P of 39. You can verify this with a tape measure of course-The P is the luff of the mainsail, so shackle a tape to the main halyard and pull it up to the sheave, then meassure to the top of the band on the mast (even with the top face of the boom)-this should be 39'. If it is more, you do probabaly have a taller rig, but I am pretty sure you have the 46' I.
If you look at the specs, there is a 46' I and a freeboard of 4'4" at the bow, slightly less at the stern. Use the bow freeboard to be safe and you get roughly 50' 4" for height above water-although since the base of I is about the location of the chainplates, 50' is closer to reality...which matches one of the brochures showing a "mast height" of 50'..
I have to comment that this is a very unusual spec to publish (most designers do not do this)-at least without clarifying it to mean "height above water".
This value is not based on any mast dimensions and has nothing to do with sail area or sizes-it just refers to the height above water AT NORMAL LOADING...If you have an empty boat, it will be higher, if fully loaded, it might be lower..get the point?
Back to your issue: This 50' does NOT account for any antenna or instruments above the mast, so add something for that..
If you still are convinced you have a tall rig, and want to calculate this, take the "I" measurement (from your documents, from your own measurement or from your sailmaker), and add 4'4" for freeboard, plus whatever you have sticking above the mast for instruments or antennae..
To measure the I yourself, shackle the genoa (center) halyard and hoist the tape up to the sheave. Measure the length with the "smart" end of the tape flat on the deck right next to the chainplate for the upper shrounds. This should be about .5-2" LESS than the published or actual I measurement.. Of course once you have gone this far, take the tape down to the water line and you will know everything except for the stuff sticking up above the rig!
Having said all this- take the advice of my fellow denizens-they are pretty smart!!
S
When do you plan on doing the trip? I want to cross around the middle of May and head up the coat before Hurican seaon hit's. I would go earlier but I have entered our E34 in the Sol Del Sol Regatta April 24th and won't be back until mid may. I draw 4'10" should that be of concern?
Andy
