It's a 6-pack (for $8.99) ;-)I looked at your link, but the price stated is $8.99.
I paid about that or a bit less for some similar bulbs from Fisheries in Seattle.
I definitely would like to, but the nearest rigging shop is a 7-hour drive from here (Charleston, SC).I would work with a professional rigger on this. Advice, discounts, and you can still do as much yourself as comfortable with.
Everything needs to be inspected and reviewed, including chainplates, toggles, turnbuckles, mast rake and so on.
"Weakest link in the chain" etc.
Sounds like you know more about this stuff than I do.
Not everybody realizes the turnbuckles need to be changed too, and chainplates--including the bow stem fabrication--need a hard look.
My own inspections have flunked several times, so just don't be me.
Here's one I missed from a bosun's chair, but a rigger found. The crack was inside, and not very apparent.
New rigging is a great comfort, and every owner for the next 20 years will sing your praises.
WM to make new swaged stays throughout.
The rigger (Donny) recommended Hayn. He said that the original T-ball end fittings that the spar maker (Kenyon) used may not be available, but Hayn have an equivalent one that mates with the bearing plate that the original ones were designed for. He also said they may offer a lollypop-shaped end fitting that fits in the slot and mates properly to the bearing plate. The lollipop design is apparently much less prone to the stress-crack you found in the hooked t-ball design.What T-lock swage fittings is West going to use? Hayn, or....?
Beware that some of the cheap LED bulbs sold on Amazon overheat and eventually destroy themselves. Especially during charging the batteries when voltage is higher. Yours seem to have built-in heatsink so you may be OK. Just keep an eye on them. I just replaced a bunch of ~$1 LED bulbs with a much better stuff from Marinebeam. Old bulbs would flicker on/off and upon inspection I saw solder joints failing and PCBs discolored from overheating. IMHO fire hazard. Key words to look for in a better quality bulbs are "constant current" or "wide voltage range".This weekend, I replaced all incandescent bulbs with LED ones in the domed cabin lamps.
I used these bulbs:
https://www.amazon.com/gp/product/B00LMZZNU4/ref=oh_aui_detailpage_o01_s00?ie=UTF8&psc=1
About $1.50 each.
Cheap LED bulbs will only work in one orientation because they are nothing more than a string of LEDs and a ballast resistor. BTW, about half of the power goes into heating that ballast resistor.Interesting - they only work in one orientation (polarity sensitive).
Very helpful advice - I'll keep an eye on them - I did notice that the first ones I tried (which were a little too short) got quite hot - they can't be saving much electricity (compared to incandescent) if they are giving off so much heat - you get what you pay for, as always.Beware that some of the cheap LED bulbs sold on Amazon overheat and eventually destroy themselves. Especially during charging the batteries when voltage is higher. Yours seem to have built-in heatsink so you may be OK. Just keep an eye on them. I just replaced a bunch of ~$1 LED bulbs with a much better stuff from Marinebeam. Old bulbs would flicker on/off and upon inspection I saw solder joints failing and PCBs discolored from overheating. IMHO fire hazard. Key words to look for in a better quality bulbs are "constant current" or "wide voltage range".
Here is a pic of cheap LED bulbs removed after 2 years of service. Overheating caused PCB discoloration, solder joint failure and one of the ballast resistors even fell off.Very helpful advice - I'll keep an eye on them - I did notice that the first ones I tried (which were a little too short) got quite hot - they can't be saving much electricity (compared to incandescent) if they are giving off so much heat - you get what you pay for, as always.
$9.90 is more like it. I have a pretty good idea of what goes into a good LED bulb and it ain't $59 worth of stuff, even after West Marine markup. Marinebeam was more inline with $10 price range. Even that is too high but then again it has word "Marine" in it ;-)The local West Marine store manager (whom I trust very much) recommended I go for cheap (Amazon) LEDs for the cabin lights, but to get 'marine' LEDs for on-deck/mast running lights.
The WM bulbs were a shocking price ($59 each) .. until the store manager did their new price-match guarantee, searched the P/N on-line for me in the store and sold them to me for $9.90 each !!
