ted_reshetiloff
I want to add some ballast to the port side of my 89' E 38-200 as I have about a 3 degree starboard list. Thinking 150-200 lbs may do it. Question is where is the best place to get it? A dive shop perhaps? I want to use lead and may try glassing it into 50 lb increments, then once I am happy with the list determine a way to strap it in. I dont really want to permanently attach it as things change and I may want to remove it at some point. Problem is I have too much stuff to starboard and no easy way to get more of it to port. Also I don't have the 40 gal. port water tank. The watertank was displaced (no pun intended) by and ac unit. All of my batteries, holding tank, 22 gal water tank, cockpit storage locker are to starboard. I doubt I can entirely correct the problem with lead, as I would need probably a lot more than I want to use, but I hope to at least improve the current situation by a degree or 2.
