Toe Rail track
I'm not sure if this will help or not, but at one point this summer, the marina moved my boat, and left it tied up too tight on the movable mid-ship cleat that slid on the toe rail track. The tide went out, and pop! The cleat ripped out about 4' of toe rail track before someone cut the line. The point of this is:
It looked like there were nuts fiberglassed into the toe rail track, and the 1" machine screws were secured by these captive nuts. When the force was upward, it pulled the nuts straight out of the fiberglass. Usually the load is more lateral, I guess. But there wasn't any indication that it was ever through-bolted, as the nuts were fairly close to the surface.
The marina repaired the track, but I think I may re-do it better after projects #24-78 are complete.
If I was going to reverse engineer my track, I would say:
Mark the track holes on the toe rail.
Drill a 1" deep hole with a large enough diameter to fit a nut down at the bottom.
Put in the nut, and coat a machine screw with mold release wax install the screw in the nut with the head just below track level.
Fill the hole with thickened epoxy, and allow to cure.
Remove screw, and screw down track.
You may be able to put the nut in deeper, but mine has 1" machine screws, so I think that's how my toe rail track was constructed. Good Luck! And please post photos if you do it.
-Dean
E-32
