The manifold exhaust on my A4 is melting the hose that connects to the wet-exhaust pipe (the one that runs out to the transom) causing the hose to rupture and spew water and exhaust fumes everywhere.
I can't figure out whats causing this overheating. Water is ejecting out of the transom so it appears the water pump is working, I can't seem to see anything that is out of the ordinary as far as the connection of the hoses go.
The temperature gauge is showing the engine is running at optimal tempertures so it seems the thermostat is working.
Could it be the exhaust manifold could be going bad? And is that replaceable?
This problem really has me baffled. Has anyone ever run into this sort of thing
