Desiderata
Was finally able to remove my E-27 handrails intact and will now thru bolt them back on with accompanying handrails (I made myself out of 1' teak stock, since aftermarket rails have too short a span betwwen loops) on the inside cabin to same bolts. Any suggestions as to embedding material?
I'm also gathering opinions on thru-hull fittings below the waterline. Bronze or nylon?
Lastly, my single cylinder Yanmar diesel (heck, I don't even know the model #!) is spewing an inordinately amount of oily smokey/residue out exhaust, particularly when throttled up a bit. Supposedly 200 hrs. on rebuild ?
Mike & Cheri McNulty
