1998 Ericson 380 offshore for sale
Larry Modrcin
The last 380 Ericson is for sale built in 1998. beautifull boat with lots of extras, located in Tierra Verde FL, asking $189,000, contact Larry Modrcin, at 727-365-3937
WICKED WAHINI
38’ Pacific Seacraft Ericson 380 offshore
Year: 1998
Current Price: US$ 189,000 (10/09)
Located in Tierra Verde, Florida
Hull Material: Fiberglass
Engine/ Fuel Type: Diesel
Additional Specs, Equipment and Information:
Builder/Designer
Builder: Pacific Seacraft
Designer: Bruce King
Dimensions
LOA: 37’10”
LWL: 30’6”
Beam: 12’
Draft: Bulb keel 5’3”
Displacement: 15,500 lbs
• Lead Ballast : 6400 lbs
• Sail Area: 709 sq. ft.
• Auxiliary Yanmar 3JH2E 38 hp
• Mast Clearance 56’
• Head room 6’2”
• Births: 7
DESCRIPTION
• BOAT NAME: Wicked Wahini
• IS THE NAME TO BE RETAINED: NO
• FORMER NAME; NONE
• MAKE/MODEL: ERICSON 380 OFFSHORE
• DESIGNER: BRUCE KING
• BUILDER: PACIFIC SEACRAFT
• WHERE BUILT: FULLERTON, CA
• YEAR BUILT: 1998
• MODEL YEAR: 1998
• YEAR /MONTH COMMISSIONED: JUNE ,1998
• HULL NO.: PSE38025E898
• REGISTRATION NUMBER: 1070032
• FLAG: US
CONSTRUCTION
• HULL: Fiberglass
• DECK MATERIAL: Fiberglass
• STEERING SYSTEM: Wheel
• RUDDER TYPE: Spade
• KEEL TYPE: Keel with bulb
ENGINE
• NO OF ENGINES: 1
• MAKE/AGE: Yanmar/Original
• MODEL: 3JH3E
• HP: 38
• FUEL: Diesel
• NO. OF CYLINDERS: 3
• COOLING SYSTEM: Heat exchanger
• LAST SERVICED: 10/22/2009
• HOURS RUN/DATE: 807 hrs 10/22/2009
• TYPE OF CONTROLS: Whitlock
• DRIVE TO PROP: Direct shaft drive
• TYPE OF PROP: 3 blade Max prop
ELECTRICS
• VOLTAGE: 110V/12V
• NO OF BATTERIES: 1 engine, 2 house, 1 generator
• CAPACITY:
• MAKE: Lifeline AGM 105AH each
• YEAR: 2005/2006
• METHOD OF CHARGING: Alternator and Freedom battery charger/ Inverter
• Alternator: Standard Yanmar
• GENERATOR: Panda PMS4200 Plus
• SHORE POWER: yes
• SHORE POWER CABLE: yes
TANKAGE
• NO OF FUEL TANKS: 1
• MASTERIAL: Aluminum
• CAPACITY OF FUEL TANKS: 60 gallons
• NO OF WATER TANKS: 3
• CAPACITY OF WATER TANKS: 105 gallons
• HOLDING TANK: yes
WATER SYSTEMS
• MUNUAL: seawater in galley sink, and fresh water in galley
• Pressurized: fresh water
• SEAWATER: deck wash down
• WATER HEATING STSTEM: yes
• PURIFIER: Seagull purified water system
RIG
• TYPE: Sloop
• SPAR MAKER: LeFiell
• SPAR MATERIAL: Aluminum
• STANDING RIGGING MATERIAL: Stainless steel wire
• LAST REPLACED: Original:
• RUNNING RIGGING MATERIAL: Core braided line
• MAINSAIL REEFING: slab reefing 2 points
• HEADSAIL ROLLER REEFING: Harkin
• SPINNAKER POLE: No
• WHISKERPOLE: yes
• BOOMVANG: Rigid
• HYDRAULIC BACKSTAY: Yes, Sailtec model No. 10L1 with split backstay
SAILS
• TYPE: Main
• MAKER: Ullman
• YEAR: Original
• TYPE: Genoa 155%
• MAKER: Ullman
• YEAR: Original
• OPTIONS:
• Harkin Batt car system with full batten main
• Lazy jack system with stack pac sail cover
WINCHES
• GENOA WINCHES: 2
• MAKER Harkin
• SPEED: 53.2STC
• SELFTAILING: Yes
• ELCTRIC: No
• SHEET WINCHES: 1
• MAKE: Harkin
• SPEED: 40.2STC
• SELFTAILING: Yes
• ELECTRIC : No
• HALYARD WINCHES: 2
• MAKE: Harkin
• SPEED: 32.2STC
• ELECTRIC: No
ACCOMODATIONS
• NO OF BERTHS: 7
• DOUBLES: 3
• SINGLES: 1
• NO OF CABINS: 2
• AFT CABIN: 1
• COOKER TYPE: Force 10
• NO OF BURNERS: 2
• OVEN: Yes
• GRILL: no (Gas line for grill yes)
• FUEL: Propane
• MICROWAVE: Yes
• FRIDGE: Adler Barber
• FREEZER: Adler Barber
• ICEBOX: None
• SINK: Double basin
• CUSHIONS AND BIRTHS: Tempur-Pedic foam
• NO. OF HEADS: 1
• MAKE: Groco
• HANDBASINS:1
• SHOWER: 1 plus transom
• CABINHEATING/AIR CONDITIONING: Yes 16,000BTUs
• UPHOLSTERY?COLOR SCHEME: Teal Ultra-suede and turquoise pattern in cabins
• INTERIOR CONSTRUCTION? WOOD TYPE : Teak and Teak plywood
GROUND TACKLE
• PRIMARY ANCHOR: Stainless Steel Bruce 35lb
• SECOUNDARY ANCHOR: Fortress
• WINDLASS: Electric
• MAKE: MUIR VRC 1200 Electric windlass
NAVIGATION AIDS
• COMPASS: Richie SP-5
• AGE: Original
• ECHOSOUNDER: B&G dept sounder and Raymarine Depth sounder
• AGE: B&G original, Raymarine 2005
• SPEED: B&G
• AGE: Original
• LOG: B&G
• AGE: Original
• WIND: B&G
• AGE: Original
• VHF: ICOM
• AGE: Original
• GPS: Raymarine
• CHARTPLOTTER: Raymarine
• RADAR: Raymarine
• AUTO PILOT: B&G
• AGE: Original
• WEATHER DETECTION:Sirrius/ Raymarine
GENERAL EQUIPMENT
GAS DETECTOR: Yes
SEARCHLIGHT: No
HORN: No
GANGWAY: No
FIRE FIGHTING EQUIPMENT: Yes
BILGE PUMPS: Manual and Automatic
SAFETY EQUIPMENT: Yes
NAVIGATION LIGHTS: Yes
GUARDWIRES/PULPIT/PUHPIT: yes
SPRAYHOOD/DODGER: Yes, Hard dodger with overhead led lighting
RADIO/CD: Yes
DAVITS: Yes
SWIMMING LADDER: Yes
BIMINI: Yes, with complete summer and winter enclosure
DINGHY: No
OUTBOARD: No
WARPS: No
FENDERS: No
BOATHOOK: No
ENGINE SPARES: Yes
LAST SERVICED: 10/23/2009
CLOCK/BAROMETER: Yes
COCKPIT CUCHIONS: Yes
PEDESTAL COVER: Yes
DORADES: Yes
COCKPIT TABLE: Yes
WINCH HANDLES: 2
EMERGENCY TILLER: Yes
HEART L-2000R BATERY MONITOR: Yes
HELLA FANS: 4
CORIAN COUNTER TOPS: Yes
RUNNING RIGGING RUN AFT TO COCKPIT: Yes
HELMSMAN CHAIR: Yes
Show us More!
Priced more favorably than a late-90's Tartan of similar size, and with an arguably better sailing pedigree, that is indeed one Rare Ericson/PSC.
:hail:
Worth mentioning is the Ericson interior has better accommodations for offshore sleeping than most boats of the era that had "RV" interiors with easy chairs and curved couches.:mad:
You should add some pics.
:cool:
BTW, which keel?
I would zip right over and buy it, but my weekly lotto ticket seems to be defective, yet again.
Regards,
Larry Modrcin
Thanks for the comments, I took your advice and added some pics, I have a full list of extras if you would like to see them, Larry
ted_reshetiloff
Really?
The listing says 205 gallons of water capacity in 3 tanks? Can you confirm this? and if so where are these tanks located? Love the transom, been dreaming of "fixing" mine...
