A nice substitute solution for water waste diesel deck caps. Plumbers pressure test cap.
corkhead
Julian Ashton
These plumbing integrity caps work great as deck caps for water, waste, diesel.
$6 and they fit very snup. No issues after 4 yrs. No tool required to access tanks
Sorry, but a raw bolt sticking up on a side deck is unacceptable. Every trip on a boat? Ever put your knee down? Ever have a kid running around the deck in a slip or at anchor? Don't mean to be harsh, I know deck fill caps are hard to find and this just isn't a good solution..
I've tried ordering multiple caps on line, then returning the ones with incompatible threads. If necessary, remove the current deck fitting and install a new one, which can be a chore with short, stiff hoses.
I don't think this is a controversial recommendation.
So the regular 1.5" caps I see online are problematic? Seems it should be rather simple. I ordered a couple a few days ago, but they've yet to arrive. Guess I'll find out soon.
corkhead
Julian Ashton
I appreciate your feedback!
Agree that the bolt end is hazardous. In an emergency where the sea has be kept out of the fuel or drinking water for several days it would be pretty handy to have the option, tho,
Second Star
On my E28+ the fuel fill is on the combing of the cockpit nearly vertical and out of the way. The plumbers plug would be OK there, especially with the bolt trimmed shorter and peened over so the wing nut does not come off. I may get one in case I drop a standard plug into the drink.
HerbertFriedman
I certainly agree that a bolt sticking out in a walkway is dangerous but my diesel fill port is not in a walkway so I plan in trying it out there only. I do see a problem with the wing nut, I plan to replace that wing nut with a regular hex nut, and in stainless too. The bolt looks like chrome plated and will soon rust so I need to think of how to replace that with a stainless bolt as well.
