u079721
After a very long Saturday afternoon aboard, I finally was able to install new engine control cables aboard my E-38. On of the original cables had snapped right where the factory had run it through a 3" diameter bend, in spite of the Morse spec that the bend be no tighter than 8".
For the new cables I went with Teleflex Xtreme cables, with an 4" minimum bend radius. Even so, I felt I needed to find a way to run the cables through a much more gradual bend. Previously they were held above and out of the way of the radial drive by a metal strap. To give me more room, I fashioned a short 2" bracket to hold the new cables below the radial drive. The difference in the amount of force required to work the gear shift is just amazing.
If you're interested, I have included before and after pictures.
