This follows up a posting on another thread by Kieth P about upgrading the mainsheet tackle on his E-33
I had the same problem - that main on the 33 is quite sizable! The factory system - 'twas originally a 6 to 1 tackle on my boat (hull #25) - was fine for racing with a crew of young, strong, eager guys - was not ideal for a "mature" owner with similar crew. My solution was a custom 5 to 1 / 10 to 1 two speed system put together by the fine folks at Harken. I've used it for several years now and found it to be a good solution. If I did this right, there should be pictures attached.
Mike Oxborrow
E-33 JP Foolish, hull #25
Mike Oxborrow
