Rocinante33
Pokey,The following is an illustration of the mainsheet on my Olson 911. It's also the same system used on a Farr/Mumm 30 and other modern race boats.
I likethis system because it keeps the mainsheet length to a minimum and because the fine trim has enough throw (adjustemnt) to go from a beat to a reach.
Note that the block sizes shown are Harken Carbos.
Your design looks real fine (and you diagram is really helpful to visualize it), but after looking at it for a couple of days now, I have a question about it. In one contiguous system like your mainsheet, why would you use a 40 mm Block (max working load 970) and then use a 75 mm block (mwl 2426)? It seems like the 75 is so oversize for the system. The 40 will fail so much sooner that it isn't even close. I can understand that you want a bigger line for the gross control which then necessitates a somewhat larger block, but that difference in size seems extreme to me. Any comments on that disparity in size & strength?
