I recently replaced the starter key switch and push buttons on the engine control panel. I had always found that after sitting over the winter the contacts on the switches would be a little corroded and sometimes needed to be switched a few times back and forth to get them functioning. The switches were also a bit stiffer than I thought they had probably been when new. Last month I had to fiddle a bit with one switch as I was trying to start the engine to transit the bar after a day of...
