I used a combination of CLR and elbow grease with scotch bright pads to clean it up. I also cleaned out the tubes using an old wire coat hanger.
Wiped cleaned with alcohol and then spray painted with Rust-Oleum primer/paint. Final product. Just need to let the paint harden and then I can install new zinc...
