The athwartship bulkhead was reinforced by laminating on 3/8" plywood, retabbing to the hull and adding a nice solid hand hold. The nav table adds inherent stiffness by tying back to the hull bulkhead.
The berth has removable supports that will allow larger things like a water maker or inverter to be installed inside. The volume is essentially continuous...
