As I mentioned in Part 1 of my blog I replaced all the old circuit breakers with new E-T-A breakers with ratings now correctly matched to the circuits so as to protect both the wiring and to the type of device or load attached to the circuit. As an example I’m using a 5A circuit breaker for the stove circuit as the only load on the circuit is the propane tank solenoid fed via the LPG control switch in the galley.
I have also wired all the boats loads to be fed from the DC panel, no direct...
