NateHanson
I've heard a couple disparate opinions on repairing a bent rudder stock, and I'd like to see what the fine folks here think. The scenario is a spade rudder with a 1 1/4" stainless pipe rudder stock (1.65" o.d.), bent about 10 degree right where the stock enters the blade. I've heard from someone who fixed this problem by cutting away the top 6" or so of the blade, cutting off the stock below the bend, machining a piece of stainless rod to fit inside the stock, and fitting another piece of pipe over the other end of that. Welding it all with 316 wire, and polishing it up good.
A fellow who makes rudders, however, has expressed the opinion that without a whole lot of fancy passivating, and metalurgical mumbo jumbo, no stainless weld below the waterline (especially in a low-oxygen environment like the inside of a rudder) can be trusted for more than a few years.
For me the question is academic, because I have worked at splitting my rudder blade in half, to remove it from the stock and web, and that painful process (yes, the foam is totally dry and holding like crazy glue stuck to duck tape ) has me solidly committed to a rebuild-the-rudder course of action. Or find a replacement.
Anyways, the subject has gotten me wondering, and when I wonder about stuff like this, I like to hear what you folks think about it.
Thanks, Nate
Thanks, Nate
