LeifThor
All the refits done to Bee’s Knees since we purchased her in 2019-
Engine-
New Raw Water Thru-Hull & Valve
New Custom Gas Tank Installed
New Gas Inlet and Hose
New Carburetor
New Alternator
New Distributor and Caps
New Fuel Pump
New Crank Case Kit
New Fuel Filter Housing
New hoses
New Exhaust System
Water Muffler Cleaned of Rust from Engine
New Anti Siphon Valve
New Raw Water Strainer
New Fresh Water Rinse System
New Spark Plug Wires
New Custom Control Cable
New Engine Blower
New Bilge Pump (2)
Repacked Shaft (3)
Fiberglass work on Hull around Shaft Log
Repaired Transmission
Engine Mounts Cleaned, Treated, Painted
New Custom Atomic 4 Propeller
Helm-
Fiberglass work on Wheel Helm Mounts
Repaired and Re-calibrated Auto Pilot
Repaired Radar
Replaced Compass Light
Electrical-
Added second battery
Replaced Battery Wiring
Mast and Sails-
Bulkhead Replacement (3 of 4) Bulkheads
Mast Reinforcement Repair
New Spreader
Mast Baseplate Replacement
Chainplate Repair
Chainplates Through Deck Rebuilt
Rewired all Electrical from Mast
New Anchor Light
New Deck Light
New Running Lights
New Rigging
New Running Rigging
New Running Rigging Blocks
New Deck Organizers
New Reef from Cockpit added
Repaired Genoa sail
Repaired Roller Furling
Boom Vang Repair
Out haul Replaced
Cabin-
Re-tabbed all Furniture to Hull
All Port lights (windows) Removed, Rebuilt, Installed
New Head Portlight
New Main Cabin Hatch and Framing
New V Berth Hatch and Framing
New Custom Bed for V Berth
Removed Dangerous Wood Stove
New Large Flat Screen TV
Repaired Torn Cabin Sole (3)
New Floor Access Plates
Additional Access Hole and Plate Added
Alcohol Tank Removed
Rotted Wood under sole replaced
Leaky Water Bladder Removed Under Cabin Sole
Hull Under sole deep cleaned (100s of hours)
Dinette Turned into Lounge
Curtains Repaired
Repaired and Varnished Storage Hatches around Entry Way
Phone Charger added to Entry Way
Tiki Theme Embraced using Christmas Lights & Fake Flowers Added
Closets & Shelves Painted
Thru Hulls in Head Removed and Capped
Repaired entry Stairs
Replaced all lounge laying down cushions with one single 6in firm foam piece, and replaced couch laying down cushions with a single 6in firm foam piece.
Removed all hardwood framing for lounge area so as to make the lounge flat, replacing table with plywood, and adding frame for a single continuous frame piece running the length of the lounge
Galley-
New Thru-Hulls
New Custom Galley Counter top
New Galley Mirrored Shelve Doors
New Faucet
Repaired Water Pump
Repaired Galley Drawers
Bad Squeaky Floor Repaired
On Deck-
New Anchor
New Chain
New Rode
Repaired Windless
New Ladder for Swimming
New Scuppers & Hoses
New Decals for Boat Name
Bimini Isinglass Repaired/Cleaned
New Electrical Cord
New Electrical Outlet for Cord
Winches Repaired & Serviced
Moved Rear Stanchions to Upper Shroud area on Deck
Safety Lines Added to Cockpit Area
Fiberglass Repairs
Stripped all wood, cleaned (brings back wood color) and sealed with Semco
Soul-
Renamed and Christened in 2022.
Next we make her outside look amazing, add Water Maker, Stove, 12V Fridge/Freezer, Solar Panels, and a new Hard Top Bimini and she’ll be ready to cross oceans.
